More than once, I've encountered display issues for the dialog that's supposed to display all inputs on a selected node. The dialog doesn't display at all. And my status line turns red with the following
// Error: file: C:/Program Files/Autodesk/Maya2011/scripts/others/detachHistoryTable.mel line 369: Object 'row1' not found.
Does anybody experience this?
I wanted to use this dialog to reorder the deformations on my mesh. Is there a "convenience" MEL command that we could use to reorder deformers manually without manually noting connections, then breaking them and reconnecting them in the proper order?
Thanks!
David
