Hello all,
Merry Christmas!
I have run into a problem trying to create follicles predictably and at selected points/vertices.
WORKFLOW:
1. Create polygon plane> DefaultSettings
2. Move from origin
2. Select any vertex
3. Hair>CreateHair>AtSelectedPoints/Faces
4. Apply
5. Warning: createHair: no hairs created
I HAVE TRIED:
1. Selecting one vertex
2. Selecting two vertices
3. Selecting three vetices
4. Selecting four vertices
5. Selecting single face (this works fine)
6. For control purposes, a nurbs plane, selectedCV, follicle appears far from actual selected CV
A hair system is created, along with follicle nodes, and optionally painteffects node and/or curve node. The problem is that the follicle does not appear to be located and constrained to the poly plane, it is still at the origin. Ideally, I can test using this simple poly plane to get workflow down. Then apply this knowledge to a mesh, reliably placing individual follicles on the mesh at selected vertices.
Let's see if we can figure this one out and post the results here. Duncan, if you are not too busy, your help is always appreciated and valued.
Best,
Jacques Broquard
