Hi everyone! I'm new in 3d painting so I need just some simple advices and guide lines.
I've modeled a simple alien character, and I've just finished to create UV coordinates for all the body, from the head to the feet, so if I open the "UV Texture Panel" with the geometry selected I can see all the UV into the 0 to 1 space, adjusted in the way that the texture applied on the geometry appears proportionate on all the body... ok.. until here all right.
I've used a seamless alienskin texture so I've repeated it 30 times.
Now I'd like add detail on the texture, for example: I'd like brighten up the palm area (for the hands and feet), or I'd like to change a little bit the coloro of the stomach... and so on.
Under the "UV Texture Panel" I've made a "UV Snapshot" and I've import the image into photoshop, here I can paint on the texture using the "UV Coordinates" like reference, but it's not very precise 'cause I don't know effectively where I'm painting, and I've to switch continuously from photoshop to maya to test.. a bit uncomfortable.
So.. inside maya if I use the "Texturing-->3D paint tool" I can't paint on the entire texture, but it repeats the painting on every single rawplug 'cause I've repeated the texture 30 times... so I thought I've to have a unique big texture not repeated, and I've tried, under the "UV texture panel", to create a "PSD Network" but it doesn't accept values above "512" for the texture resolution output, if I put something like 1024 I receive a "fatal error" and the program shuts down.
Any advices will be well accepted,
Thank you very much and sorry for the lenght of the post.
Bye!
created
Mar '07
last reply
Mar '07
- 2
replies
- 1.9k
views
- 1
user
- 4
links
