QUOTE(Joojaa @ 11/10/05, 02:19 AM)
Yes yes... not that.
The fact is not about what happens when i press it. Imaginde i was aiming for reply but mistakenly pushed edit instead. Now your mind is not aware of the difference at this point.
But se the window that appears look exactly like the reply window (there are only very minor clues). Now the brain does not notice your mainly on automation on thispoint anyway so if you have quote on youd end deleting the message anyway. Then you start tyyping and hit the submit button and bam.... You have editted the users post by mistake. And theres no way to undo this.
So the visual clue is too small AFTER youve pressed the button. So could the bar whare it reads enter post be red or something!
[snapback]219274[/snapback]
Are you refering to the colour of the buttons for "delete, edit, quote, reply"? If so then I see the "delete" and "edit" buttons for the forum as red and the other two as blue. I haven't experienced what you have but understand what you're asking. It may be better to just space the moderator buttons further apart though I also believe the current colour theme does work well.
