Im trying to put shorts on a character but when i bend the leg the waist band creeps up his body. How do I make the waist band stay put regardless of how the character is moving and rest of the shosts are moving. Is there an attribute I can paint on that portion?
Hi.You can Mesh Constraint your belt to the charactor body.Or if the belt is a separate object, you can wrap deform the belt with the shorts as the driver. Instead of making it as a cloth object.
