Yes, if you render one frame after entering a file name for a photon map with 'rebuild photon map' checked, you can then uncheck this option for subsequent renders and the named photon map will be used. If you make any adjustments to your fg settings you will have to rebuild the photon map again (re-check this option and render one frame).
Cheers,
xsi
