FSB stands for Front Side Bus. The Front Side Bus of your processor must be set to 266 (133x2) to be seen as the 1900. Right now it's set to 200 (100x2). It's highly unlikely that a virus would change your FSB setting in your BIOS, but not unheard of. What you're going to need to do is go in to your BIOS (usually the delete key or F1 when it's posting), and then go in to Frequency Control and make sure your FSB is at 266 or 133 (if it's at 133 the machine automatically doubles it to 266, so it's effectively the same thing).
Some ways it may have been changed... power surge took out your BIOS battery... uh... something grounded on your motherboard... Not really a whole lot else could physically change it unless it's always been running at that speed and you just never noticed it.
Let me know if that helped out. If you're still having problems you can contact me via e-mail. vyyper@netscape.net I might be able to help more in-depthly if you're still having problems.
[edit]Also, a 1900 is only 1600MHz just so you know.[/edit]
