QUOTE(DanielH @ 07/03/07, 01:15 AM) [snapback]269098[/snapback]
Shoot with overlapping footage, if possible.
Shoot with the same lens/focal length.
Apply tracking markers to the window frame. These are probably easy to remove in post but help you in stabilizing both shots.
*I echo all of DanielH's suggestions.
and add the following:
*Switch to steadicam as soon as possible after the crane shot is over. If possible, use a second camera. This is a psychological tip, but it'll help.
*If possible, not only use tracking markers, but _frame_ the end of the crane shot using obvious physical cues, perhaps a panel, or grid of panels on the french doors. Then frame up the same shot with the steadicam, again pushing in with steadicam at as close to the same rate as the crane to ease into the shot.
OR...
Long complicated crane, follow shots can be accomplished without Shake, by putting the steadicam operator on a platform at the end of the crane. When the crane shot is done, the steadicam operator steps off the platform and continues the shot into the room.
Look at the opening shot of "The War Game" (shot in the '60s): Riding down the street on the back of a motorcycle, then through a door, up stairs, and into a courtroom settling into the initial dialogue all without a single cut.
