hy,
for my animation i created a black plane, with should be transparent in a specific time. So I used keys. at the beginning i set one key, then i increased the transparency of the plane shader to maximun and set the another key three seconds later. But the plane does not change in transparency..Whats wrong?? Anybody an idea how can I make a plane transparency slowly?????
Animayator
hi,
if you want your plane dessolve... be sure your surface on your plane is a Lambert.Add a keyframe on the transparency channel of your lambert (Left Mouse button -> Add key) at the time you want the dissolve will start.Set time on the timebar for the end of the dissolve. change to white the value of the transparency channel. And add a new keyframe on the transparency channel.
It should work
Yep, just like Eky said, so if you did just that and it doesn't work make sure you haven't got auto key framing on ,and that you set keys to transparency, hitting s or animate->set key wont work i think.
It works, thank you very much!!!!!
