Hi,
I noticed in Maya 2011 that polygons are selected as soon as you click on the poly face. In older versions, to select a polygon you had to click on a center dot in each polygon. The problem that I have with this new method is that if i marquee select, and I only want certain faces in the back of my object from a certain view (in wire frame mode), its going to select all the faces in the front. as well.
I can bring back the center dots in the Maya Display options for polygons, but there just for display, they don't work the same way as they did in older versions. Also,if possible, it would be nice to have that new "poly face turns red when your mouse is over it" off. But I can live with that, but the new selection method is hurting my work flow.
