QUOTE(KrisSah22 @ 06/02/08, 03:58 AM) [snapback]286583[/snapback]
Now you are obviosly pretty advanced so , what you meant by mono ?
http://www.mono-project.com/Main\_Page
And how to do the wrapper? By the way i have Visual Studio NET 2003 (yeah old,gota update ![]() ) and i have Microsoft Visual c# and c++ express editions 2008.
going to modify your code example slightly: (It's actually probably the worst example, since there's nothing to bind)
class Vector
public :
  float x;
  float y;
  float z;
  void someFunc();
Use VC2005 or newer (express editions are fine, though you can't keep all code in a single sln).
Create a CLR class library project type in managed C++, link to whatever lib you are wrapping (in your example your Vector code), then do the wrapping like this:
namespace MyClassLibrary
public ref class NETVector
public :
   NETVector()
     v = new Vector;
   ~NETVector()
     delete v;
   // wrap funcs
   void someFunc()
     v->someFunc();
   // wrap member vars as properties
   property float x
     float get() { return v->x; }
     void set(float f) { v->x = f; }
  property float y
     float get() { return v->y; }
     void set(float f) { v->y = f; }
  property float z
     float get() { return v->z; }
     void set(float f) { v->z = f; }
internal:
  // provide access to the C++ object to code internal to this dll
  // (can be helpful for wrapper code - this won't be available in C#).
  Vector* getVector() { return v; }
private:
  // the class to wrap
  Vector* v;
QUOTE
And then how to import this so it is ready to use in c#?
And now add the dll it generates to your C# project, now you can do:
[source]
using MyClassLibrary;
NETVector v = new NETVector();
v.x = 2.0f;
v.someFunc();
[/source]
http://www.codeguru.com/columns/Kate/article.php/c7405/
http://www.codeguru.com/cpp/cpp/cpp\_manage...cle.php/c14815/
alternatively do everything using pinvoke
http://www.ondotnet.com/pub/a/dotnet/2002/...cominterop.html
