Hi. I got an question about placing fur on a small part of a surface.
I have a rather large surface and I only want fur on a small part of it and making that part an separate surface didn't look good in the render. So I wanted the fur on that surface but only on that small part.
I tried it with painting baldness on it and that worked. But the problem with that is that when you add the fur to that surface it uses the entire surface. When you paint the baldness it still uses the entire surface for the calculation of the fur and so I have to set the density to 1.000.000.000 and maybe even larger to get a good density of the fur. And as you can understand this will take for hours to render and Mental Ray even runs out of memory.
But now is my question is there an option to only add fur to a small section of a very big surface?
I hope I will get an answer soon.
Thanks in advance.
