QUOTE(little_budd @ 10/15/08, 09:55 AM) [snapback]293416[/snapback]
1. can i have a particle be a source to 2 different particles which are not emitted from the same point(the parent particle) but from 2 distinct points.
yes
QUOTE
2.Particles(instanced objects) follow each other when they come in a certain range. range should be controlled with ease just by changing i number. acceleration and velocity should be controlled with ease.
look for the brainbugs plug.
QUOTE
3.if a goal particle is shot down. the other particle should on its own acquire a new target and start following it.
well this would be a side effect of 2
QUOTE
4. any plane can deploy flare which would tackle the incoming missile.
Just emit one.
QUOTE
In my opinion it would be much easier to do using real objects and a mel script to drive them.
Not really itd be hader to manage and slower to work with.
