QUOTE(TiMrozek @ 07/02/08, 08:03 PM) [snapback]287800[/snapback]
But it seems that particles that are part of the same system can't be animated separately.
Well actually you can quite easily. Perhaps te easiest way is to use a poly shape as goal and animate the points of the polygon goals. but thats just one easy way theres atleast as many ways of doing this as not to do it. Also 2 particle systems can drive one other particle system that blends them per particle. but yes this can be done.
QUOTE
So I guess the question now is, is there a way to get particles of 2 different systems to blob together
Nope, but the other option is possible. Off course if you use mr you can collapse the particles together reder description time. That would accomplish this.
