QUOTE(phosvfx @ 07/17/06, 11:16 PM) [snapback]242698[/snapback]
You want to access details in the blown out footage? Any chance you can get is as OpenEXR sequence? This format is designed to exactly what you want to do.
hey john,
not sure if my original post was very clear, so let me try to explain again:
the so-called superwhites in video is the range 235-255 (in 8bit YUV values) which is actually "illeagal" for broadcast because a value of 235 will be already 100% white (ie 255 RGB). but some cameras (specially DV) let you record data over 235, meaning that they won't just clip any data over 235 but keep extra detail up to 255.
now, if color correcting in fcp (and most other editing systems) you can access those values and bring them down to "leagal" numbers, which means that highlight areas which are usally just flat clipped white spots get a more gentle roll-off and keep more highlight detail.
problem is that the quicktime importer in shakes clips YUV footage at 235 in the file-in, which means no matter what you do you cant access the superwhites. bringing them down in another app (like fcp) will work, but is a lot of hassle and introduces chroma smoothing that i don't want (yet).
anyway, it seems that it just wont work in the current form of how shake and quicktime interacts, which is understandable because the program clearly wasnt designed for crappy DV footage, but on the other hand it's a pitty because it's quite important to get the most out of said footage if you want to make a film-out.
++ christoph ++
