QUOTE(hpv @ 10/02/05, 06:49 PM)
If anyone has actually gotten Maya 7's batch renderer to work, how about giving a shout out about htf you managed it?
[snapback]216159[/snapback]
Are you on mac? if so then the reason is here: http://www.highend3d.com/boards/index.php?showtopic=213813
I dont knoiw what the problem is about but atleast the guys i know who have macs didnt have thiis problem. What maya build are you on?
On pc i havent encountered any problems. Except maya does not show progress infinetly for some reason (it stops doing so after about 2-5 hour s of rendering it only reports full frames after that) it has been a recurring theme from 4.5 version now so... but thenagain who cares, its not maent that you launch batches from the ui except for small tests. BUt i havent had any problems with maya 7 so far. None whatsoever its worked well for both launcing and stopping. (offcourse because its differet therad it takes so ime for it to update)-
Anyway hthere was a lot of problems but it took a mac user who actualy knew how to use the commandline to figure the rpoblem out!
Ps. commandlines arent out, infact theyr in again after 10 years of problems with lack of commandlines.
