well, if it traverses the rendergloblas (your result) but misses the scene (shaders) then its likely that your scene file is correct... but your shader libraries links are not.
assuming you are using the stand-alone:
your problem will become more apparent when you increase verbosity past 4... there sould be some kind of indication telling you that youre libs or include files are not found... and a directory where it is looking for them
you need to first set an environment variable which directs the application to the correct rayrc (as in MI_ROOT) and then you need to customize the rayrc at that location to include the mayabase and its link statements...
there is some nice documentation on www.lamru.org telling how to set variables for cross-platform and cross-implement (maya-xsi-max) variables...
r.
