I've just installed shake 3.5x and SuSE 9.1 Professional on a dual Xeon workstation, but am not having any luck starting shake - I keep getting the following error when I type "shake" at tcsh prompt:
/usr/shake-v3.50.0308/bin/shkx.exe: error while loading shared libraries: libnrcc_lx.so: cannot open shared object file: No such file or directory
Does this look familiar? I have the feeling this is an environment variable issue, but I don't know how to proceed to set it up correctly, whould be grateful for any help I can get.
thanks,
john t.
EDIT: after re-installing SuSE 9.1 professional (different problem), I'm getting a completely different error when I try to run shake:
cohibalinux:/usr/nreal/shake-v3.50.0308/bin # ./shake
Xlib: connection to ":0.0" refused by server
Xlib: Invalid MIT-MAGIC-COOKIE-1 key
internal error: can't open X11 display
This is sounding a bit more ominous - perhaps I don't have all the libraries I need? Is there a listing of those I need to run Shake 3.5 in Suse 9.1?
It seems that some on this board are successfully running Shake in Suse, and I'd love to learn how to do this, as I've found RH9 completely unuseable - shake runs, but it's slower than a 286!!! on my system, and the mods I've tried have done nothing but trash my RH9 installation, so I went out and dropped $90 on Suse hoping for something better...
thanks,
jt
