QUOTE(trondajo @ 01/10/06, 06:21 PM)
Mayby AIC is crap for film, but it look great for my project. The presentation will be viewed on a 42" HD plasma, from a mac. And on a website i 1080p, 720p and some other formates.
The musicvideo will be showed on norwegian telivison in ordinary PALformat.
well, since you have to compress it anyway to play it of a single disk (not to speak of the web... and PAL is much lower res anyway), AIC is probably not such a bad idea as a final intermediate format.
however, for best results, i'd convert all the HDV clips to an lossless image sequence (png or iff), then do all your effects and compositing, then render out as an lossless image sequence again as your master. if you're tight on storage, consider jpeg compression. (you could olso choose QT files with png or jpeg compression if you dont like image sequences).
to play it from the mac, i'd compress it to a QT file with jpeg or mpeg4 compression, for web transmission either mpeg4 or h264 (the later uses a lot of processor power though). for the PAL transmission, render it out to an uncompressed 4:2:2 QT file and take it to a post house to play it out to digibeta.
QUOTE
And now for the wierd 25->24->25 converison.
I used the retime fuction i the Filein Node, input to 25 and output to film 24 (and interlaced to progressive). And actually by mistake the Fileout node were 25fps and AIC. After eksporting I actually tought it were 24fps, but viewed it in QT. and it were 25fps. I opened the original AIC output from FCP and viewed them simultaniossly, and there is a little differens. The frames are not identically. ut when I view it in realtime it got that little somthing you might call the X-factor.
The quality has not changed. I
