I have some shots with tracking marker that i need to paint out. Basicly what i want to do is to paint one frame and than track the paint over the entire video so that the paint follows the marker. So far the only thing I found is the stabilize the video, paint, than matchmove the video again....but there must be a better way !
Thanks
as i recal you have to make your paint stroke persistant, then right click it in the viewer and choose "add tracker to stroke". The track is applied to the entire stroke and essentialy feed into its pan XY parameters.
I agree. For the most part, you are going to need to look at each of the frames to be sure the track is taking.
You could use the clone tool to paint it out fairly quickly, then use that as your stroke persist as well.
