Hi guys,
It's my first time using particles.. I'm using sprites and I'm using an object as an emitter but when I render the shot, none of the particles are visible! Any advice would be great!! Cheers!
Pabs!
Many particle types (including sprites) don't render in the software renderer. You'll need to use hardware rendering...Check the docs for how to render the different particle types.
Change the (particle shape tab) particle type to blobby surface or other. And press 'current render type'
