Hi there,
I am trying to render out a scene using Mental Ray. For some reason this particular file will not render. It just says Rendering in mental ray and then.... Rendering completed. No frames are rendered. Can anyone think of a potential solution to this problem?
Cheers
Do you have a renderable camera and at least one renderable render layer in your scene?
Or do you run out of memory? Or memory per process (on a 32 bit application you have a 1.5 gb limitation by defult on windows, you can bump it to 3gb with a windows stratup script, and most other systems restrict you to 2,5 -3 gb).
But yes theres no info to debug on.
Error: Backend Fetch Failure
