Hi All,
So I just installed 3D Equalizer PLE and followed th instructions to extract the program using tar into my chosen directory. Its my understanding (being new to actually installing things in linux) that once extracted i should just be able to navigate to the folder in a shell, type the name of the executable to run the program and it should work. Everytime i do this it just says 'command not found'. If I do the same with say firefox which came with fedora, it runs, but not equalizer. Do I need to set it up as a path in environment variables first? and if so how do I do that? otherwise does anyone have any suggestions?
Thanks,
Justin
p.s. in running fedora core 8
