Hi Nishok,
I am sending you a script . copy this script to notepad, and save as NukeBatchRender.bat ( insted of .txt)
Script is given below...
path="c:\Program Files\Nuke5.1v2"
set /p A=[FILENAME]
set /p B=[START]
set /p C=[END]
#set /p D=[SPLIT]
nuke5.1 -x -i %A% %B%,%C%,1
Put it on your's window XP desktop.
click on the bat file NukeBatchRender.bat
one Msdos box will open.
Drag and drop your nuke file.
Select the Msdos box and enter.
It will ask you for in frame. (only start frame number )
enter
Again it ask for out frame. (only end frame number )
enter
your NukeBatchRender started .
Check your respective folder given inside the render node of the nuke workflow.
Now you can move to 2nd batch render...... 3rd......
If there any confusion please late me now.
waiting for your feedback.
