QUOTE(Joojaa @ 05/22/09, 11:17 AM) [snapback]308186[/snapback]
Most likely, that and the vista version your using. (note the qualified card wont really work well on the vista home because its missing a few ingredients on the gfx pipe)
But yes the reason they say that they qualify only those hardware is that
Its impossible to be sure of all hardware combinationsthose cards have bettwer support form tyhe gfx card vendors, so in the event you card has some ophycal flaw it can be changed its NOT necceserily the case with cosumer cardsThsoe cards implement FULL opengl. Yes its the same chip than the gforce card but the electronic conduits of the card are crippled on purpose
I am using Windows XP SP3, Not Vista.
However, I have 3 questions:
1) Do you think following link of graphic card will work better ? For Autodesk Maya 2009
Following link:
http://www.newegg.com/Product/Product.aspx...N82E16814133207
2) I want to know if "Quadro4 NVS Series" will work better.
if so, which graphic card will be better ? (the qualified card didn't say anything about them)
3) which online store will cheaper ?
From
neowing
