I'm fairly new to this whole 3D modeling thing so bare with me.
I've encountered this a few times and can't figure out how to fix it.
All I'm trying to do is rotate an object that is made up of a bunch of objects. When I do this, all of the pieces rotate at different speeds so when I get around to 180 degrees, it's in a bunch of different floating pieces.
I've grouped everything together and only select the top node when rotating. I've centered the pivot for the top node and that didn't fix anything, so I went through and centered the pivots for ALL of the little pieces that are grouped inside of the top node and THAT didn't work.
Does anyone else have any other ideas of what I could try?
This is probably a very simple/stupid question, but for some reason I can't figure it out myself. I need an expert's opinion!
THANKS!!!
