Hey.
I'm having a rather simple problem. I want to apply an existing deformer to an object, and the best way I found is the relationship editor. I echoed all the commands necessary, and as far as I can see I needed three/four commands to apply a deformer:
// Open the editor
DeformerSetEditor;
// Select the deformer key
relationshipEditorSelectKey relationshipPanel1 deformerSetEd {$deformerSet};
// Apply the deformer
relationshipEditorMakeRelationship relationshipPanel1 deformerSetEd {"obj3"};
relationshipEditorRelationshipsChanged relationshipPanel1 deformerSetEd;
I'm not even certain about the last, but that's beside the point, because I can't even get the key to be selected. I copy the command that is echoed when I select the deformer on the left panel; and it's just that one line, and yet when I run it, it doesn't select (and subsequently the next command does nothing). Am I missing something?
Thanks.
