somebody knows how to use 16 Bits maps for displacement in mentalRay for Maya ?
Guess it depends on what file format you are trying to use. IF you use tif it cannothave any compression or MR will not read it. Otherwise you can use imf_copy.exe to convert your source image to a map file.
I converted it with gmasks tip to an iff and it worked really well.
Thanks a lot Gmask, but i still have a problem and need to find somewhere to put pics in order to illustrate it.
Here they are ...
the 8bit map on a simple facet:
http://mapage.noos.fr/jmlepretre/partage/8...test/test8b.jpg
everything seem OK the color comes from a projected ramp.
now the same polyFacet with exactly the same UV's but the same map(drawing) in 16 bits:
http://mapage.noos.fr/jmlepretre/partage/8...est/test16b.jpg
??? if smbdy has encounter this problem...
(i got the same problem with different test/maps)
nice day to all of you!
Jeanmarc
www.jmlepretre.com
i can't imagine that nobody else encounter this problem!
Jean-Marc
works for me? what format do you use?
