Hi everyone, 1st post for me =0)
On my home workstation I have a GForce4 ti4600 from Leadtek, running as a Quadro4 900XGL, with two NEC 22" monitors. The card has the usual Dsub and DVI connectors which I am utilizing with DVI to Dsub cables (and Dsub to DVI).
I'm having no trouble running both monitors at 1600x1200 @ 85hz.
BUT when it comes to running Maya, I can only use the second monitor for a few things like the outliner window. The main issue is that particular windows like any viewport or hypershade or hypergraph window will not update/refresh in the second monitor. This is a major pain that I would L O V E to fix.
I'm beginning to wonder if I should start looking at expensive DCC cards on the market (say it ain't so!).
One thing to note, is that on my business workstation, we've got an actual Quadro4 750XGL running dual displays and the SAME problem occurs there.
Any and all insight is much appreciated, thank you!
/Alive
