2 Characters for critique *DELETED*
Post deleted by Animal-man
I think he’s cool, definite style and a little cartoony. I like it, is the stubble a texture, fur , or paint effects?
FF was done using SubD’s.. Do SubD"s animate well.. You need to work with a lower version or a proxy model. If you are used to working with nurbs it will take some getting used to.
Great model.
Only problem that jumps out at me is the way the cheekbones and nose fit together… and the shape of the nose up along the bridge. I think these areas could be better analysed.
Bone structure of cheekbones and eye sockets is fantastic…
Great work, thanks for sharing.
-Steve
If you are going to animate with subdivs, make sure you have all your modeling tweeking done before hand. My Animated head was done in Sub Div, but created by Polys. If youare still converting back and forth from the two, you may lose your history.
This also applies when you are animating a character with bones. My instructor said it was possible to do all your animation in polys and then convert them all to sub div afterwards and it should work out fine… this was not the case for me. I lost everything. I felt like taking a… oh never mind about that.
Anyways, they do animate nicly, but somtimes would take longer to render out than polys/nurbs.
why deleted???
characters for a secret movie? 8)
