Hi,
When creating a composite or project, you can choose the settings supplied for HD. Just click the drop down menu in the pop up window and choose the standard you would like to work at.
If you are mid project and need to change the composite settings, select the composite and in the composite controls and select the output tab. You will find all the settings for the composite which are fully adjustable.
Regards
Grant
DISCREET EMEA
