3 Questions urgent!
1.What is the difference between offseting a curve and dublicating the curve and moving it to do for ex. loft between them.
2.If I want to do merge edge tool and the both edges lies one above the other how should I select them since I can sekect only one of them I know the merge multiple edges but that is not a suitable method for me.
  1. What is the difference between stiching the surfaces and attach surfaces i.e what is stiching used for?
many thanx to u
Offset actuall modfies the shape of the curve, Duplicate makes and exact copy
Go into line component mode, select the two edges and then use merge multiple edges instead of the merge edge tool
Stitching does not convert two surface sinto one whereas attach does
Because nurbs are 4 sided you culdnt very easily make cross shaped shapes (or not effectively anyways). But youd still wnat the modell to apear as 1 surface so you stich to keep them aligned! Or just plain make them aligned.
See patch modelling!
… this tool’s selectn mode doesnt toggle the selectn, so there is no issue. The tool completes an op if you leave the tool, reenter it, or select a new, third, edge.
then what offset curve used for , I thought it like dublicate and move but since it alters the curve shape what can I do with this tool
Hi.
It keeps the same distance from the original curves.(I think.)
So, making a race track is a good example.
If you duplicate and scale it, the distance from the inside curve to the outside one is going to be different.
I have a question too.
Is there a way to offset curves without kinks?
Like the “Border” option in Softimage3D.
