How do I make a 45 degree cut in a polygon object? I've tried the poly cut faces tool, but it doesn't snap to anything so I have to guess when I'm around 45 degrees. But if I guess, then things don't line up when I try to connect it to another object with a 45 degree cut.
Basically I'm making some architectural moldings from extruded polys, and I want to cut the corners of two overlapping pieces, delete the faces I don't need, and then weld the vertices of the touching ends together. If I don't get it right then it throws off shading in those areas.
Thanks for any help.
Tom
