8 Bit Noise From Keys
Hi there, I'm keying uncompressed 8 bit HD footage shot against green. When the key is made the footage really deteriates in the none green areas. Huge ammounts of noise appear and pixels..
I usually switch matte back into the original footage but can anyone tell me why this happens cos it makes the footage look crap!
well, it depends how the footage was originally shot and how you key it (maybe to some compressed codec and you use keylight? then it's compression artifacts i guess).
if you put up a lossless frame and your script it might be easier to give you sound advice.
++ chris
