Well I'm glad you had good results, because in my case I had a hard time getting something correct.
For example, if you do an extrusion on path and close the extrusion (creating a close rail, for example), the rail is twisting in Y axis (along the path), so the end is upside down. Also, the Birail always gives me a distorted surface, even if centers and operator stacks are frozen. The Four-sided also gave me troubles.
So if I have a serious nurbs job to do, I will try to avoid XSI as much as possible! I prefer to use SI3D for that.
Salutations - Cheers
Bernard Lebel
