hi my friends
it is about a week i am thinking about ocean and enviroment of it
like Nemo cartoon
how can we have both of surface and sub water in one Shot ?
for eg : upper half of shot is air and other one is the world of sub ocean
so i have another question , is there any solution to make the coming and going of wave of ocean to the beach of an island ?
sorry for my bad english
thanks
Hi, I have found it significantly easier to set up the 2 environments and render them separately, then combine them in a compositing application.
There are many methods that have been used for waves on beach...you could set up a specialized shader... or animated planes that draw up and down the beach with waveEdge textures that fade in and out...or create a nurbs loft from curves and animate the curve edges to simulate the water edge. You could even emit particles/sprites from this curve for extra detail...or you could use RealFlow or similar product (but this is a HEAVY solution)...or...many ways to skin the cat...
hi
thanks for your answers
but about your second answer
i have to use the Ocean of maya , do you think the ocean have this ability itself ?
If you are using the ocean, then you might use wake emitters with texture emission at he the shoreline, but it will take some tweaking to get the results that satisfy...
QUOTE(bjohnston @ 11/13/08, 09:44 PM) [snapback]295124[/snapback]
thanks my friend i'll test it
