A simple expression question
i have writen this expression:
int $a=9;
do (time<28)
object.rotateY=$a;
$a=$a*2;
while (time=29);
maya said my expression invaild,why?
thankyou
Check your loop syntax. It's either do while(something), or while(something), not do.
Specializing in Scientific Animation and Visualization - www.scimation.com
Ok, first, you have to use while instead of do
ie. you have do (time<28)
should be while (time<28)
your script should be this:
int $a = 9;
while (time<28) {
object.rotateY=$a;
$a = $a*2;
check also that your object is actually called "object" and that there is a object.rotateY attribute [ie. if it's called nurbsSphere1, there won't be a object.rotateY]
check also the syntax regarding "time" and what it returns
make sure to refer to your online help manuals.
TJ Galda
Technical Director
The Animation Group Ltd.
