A7V & VX1 not booting?!?!
Well I have seen others complain about how an Oxygen VX1 hangs when using Maya, but my system won’t finish booting
when i install my oxygen vx1 card into my system: I have read the other posts and have installed the following:-
  • Window 2000 sp 1
  • latest via four-in-one driver
  • latest windows 2000 agp support fix file
and upon reboot it shows the Win2K splash screen, the progress meter finished but then it goes black with a flashing
cursor??? Any solutions to this issue? I have the latest Oxygen drivers ready to install as soon as I get past the boot!
Thanks,
Mike
View my Maya project progress at:
http://www.allenagenda.com/projects.htm*
Oh yah, I have a 1.0 Ghz AMD athlon chip…that is why I installed the latest via chipset driver…
I set up a VX1 with a KA-chipset motherboard (Athlon Slot-A) on the weekend, with a Tnt2 PCI as the second card. I found that I needed to boot to PCI first, then install the VX1 drivers and set it to boot from AGP after that. I used the new drivers, which are dated March 28th.
Sean
Thanks for the input! I rebooted and pressed f8 to get into VGA safe mode. Then I installed the latest win2k VX1 drivers
and rebooted and it works now. Using Maya 3.0a I notice that when I change from the move, rotate, scale tool the selections have to be clicked several times before selection handles (x,y,z) change from one mode to the other. Do you get this?
