Hi,
I just installed Shake 4.1. Everytime I try to render a FileOut-node I get the usual flipbook assuming a correct render but...not one file or frame is to be found in the appointed output directory.
Would this be the Compressor 2/QMaster problem? I'm rendering non-compressed Quictime for preview and the usual .IFF-frames for master output. Untill now: not one single frame or .mov rendered. Any suggestions are most welcome...
Thanks in advance
AlexFeathers on Wings
pardon me for asking, but do you render with a flipbook or a file out command?
also, any console messages?
and any weird characters/permission issues at the place you're rendering to?
++ christoph
Always a file out command, there were no console messages or special permissions.
The output folder "output_files" is a subdirectory of a folder named "K
Do you have the UB version of Compressor installed? Shake 4.1 won't work with the older version of Compressor.
http://docs.info.apple.com/article.html?artnum=303967
