suppose i have 50 shaders(blinn) assigned to 50 objects,now if i want to change the diffuse values for all the surfaceShaders with mel, i guess i need to access the surface shader Closest i got was with -listConnections -type "shadingEngine" pSphereShape1;
but this returns the shading group.what i want it to return is the blinn node so i can access the diffuse attribute i need to change.Please help.
PS: if i get this answer i guess i will also be able to duplicate a shader say 10 times thru mel and then assign it to various objects.am i right.
Anxiously waiting!
Thanks in advance!!!
Check out http://www.ewertb.com/maya/mel/
Brian has some great Mel help there for this kind of thing.
Also you said you want to change all shader diffuse values, will this do what you want?
for($blinn in ls -type "blinn"){
setAttr ($blinn+".diffuse") 0.666;
Thanks a million friend.I am going thru brian's pages just now.i'll try to find my answer there.If i still have a problem i'll be posting here again.
PS :i feel like a fool ,while you guys are so cool !!(haha)
thanks once again.
