The subject I think is self explainatory .
Help me please on RH ES 3.
Thanks
Thanks
with a 2.6.x kernel you have full read access on your NTFS Partitions.
you maybe need to load the ntfs kernel module
modprobe nfts
then you can mount it read only as root with
mount -t ntfs /dev/hda1 /media/mountpoint -o defaults,umask=000
or put a line in /etc/fstab like
/dev/hda1 /media/mountpoint ntfs defaults,umask=000 0 0
i’ve wrote a (german) howto about this here
<a href="https://knecht.homelinux.net/phpBB2/viewtopic.php?t=203&highlight=fstab+ntfs" target="_blank">https://knecht.homelinux.net/phpBB2/viewtopic.php?t=203&highlight=fstab+ntfs
If you want to write from Linux to NTFS, you can use the OpenSource Programm “captive ntfs” or the commerciall version “paragon ntfs for linux”
both works, but captive is cpu intensive when writing on ntfs. paragon ntfs is much better and it costs "
captive ntfs
http://www.jankratochvil.net/project/captive/http://www.jankratochvil.net/project/captive/
paragon ntfs
http://www.ntfs-linux.com/http://www.ntfs-linux.com/
greetings
knecht
