Hi there! Is there an Accom DDR plugin for AE5.0. We have a plugin here for 4.1. We have been using 5.0 and even even 5.5 for quite some time now. So anybody here know where I can get the plugin?
if you want i can send you it. (130K) I got it from another fellow about a year and half ago. I am using ae5.5 and have no problems. If you have osx you might be able to use the command line tool wsdrcp which does a transfer of an sgi frame to the accom. I think you can dl it from accom. (I have the 2xtreme and use wsdrcp rather than sending through AE. (but) I also have a raid array on a unix box).
Oh yeah (this may be easier) if you are on a windows box (NT/2k/XP) you can use the rcp command. Its actually faster than going through AE.
EX:
rcp -b ./path/filename.yuv 2X:1000
1000 is the frame to send to on the ddr
filename.yuv is the rendered frame to send to frame 1000
(your frames should be yuv and 720x486)
just make a loop that sends your sequence.
good luck
