Hi everyone!
I'd like deactivate (uncheck) or clear the map that I have in the Diffuse Channel of my 3dsmax materials.
The fact is that there are hundreds of materials in my scene and it's quite tedious to do it manually one by one.
I'd like to know if there is a script or a tool inside 3dsmax with which I can make the same operation (in this case deactivate the map of the diffuse channel) for a lot of materials automatically.
Thank you very much for any help.
P.S. In my scene there are both VrayMtl and Standard Mtl, if this is a problem I can use a MtlConverter to make the materials all of the same type.
