Hello,
I'd like to use the addAttribute command to create a float attribute connectable to a shader.
In C++, I do that with :
static MObject aZeroValue;
MFnNumericAttribute nAttr;
aZeroValue = nAttr.create("zeroValue", "zv", MFnNumericData::kFloat);
nAttr.setConnectable(true); // default value anyway...
nAttr.setDefault(0.0f);
So I get a float field, with on the right side a map button.
I thought it was thanks to the setConnectable() function.
But how can I do that with the addAttribute command ?
There isn't "connectable" switch, but this attribute is by default set to true.
But there is no button created...
Thanks.
