Adding a bag to my character
I have a character that needs to carry a bag on his.. back.
In fact, he will be carrying it exactly the way Lara Croft does (you probably haven't noticed, but she DOES wear one).
He needs to be able to run around, jump etc., but he will not be using the bag for anything - it stays on his back.
My question is: What should I do about the bag, when I rig my character? It needs to remain somewhat stiff, and what about the straps? Should I model them into the character or should the remain seperate models like the bag?
Thanx,
Peter
P.s.I wasn't sure whether to post this under animation or modelling. Hope it didn't end up in the wrong place.
first,I do not speak english well
I think your problem maybe can solve with cloth simulate
1: get a nurbs cylinder
2: assign cloth to this cylinder
3: set local cloth cluster on cylinder's point at shoulder
4: take a iso curves on this cylinder
5: extract curve from this cylinder
6: create chain from this curve
7: envelope you bag with chain
8: give gravity force to originality nurbs cylinder
9: set radom expression on gravity's strength
that is all,I hope this can help you
http://www.visualnat.com
my lord moses -that technique is a little overblown
  • make the bag part of your character model and set your skeleton up a little differently - use the linked paradigm command to automatically shift the bag around when the character does things or expressions if you have the brain for it- aside from that - try a little keyframing - it takes less time than worrying about simulations a lot of the time.
  • Non smokers die every day.
Lara wears a backpack?
wow.
c'mon, how did you think she carries around her feminine nessesities: eye shadow, lip balm, hair brush, nailpolish, desert eagle.....?
