Hi.
I have an object called 'attrDest'. I wish to add a vector attribute to object called 'atVector'.
When I do this from the UI 'add attributes' menu I see the following in the script editor:
addAttr -ln atVector -at double3 |attrDest;
addAttr -ln atVectorX -at double -p atVector |attrDest;
addAttr -ln atVectorY -at double -p atVector |attrDest;
addAttr -ln atVectorZ -at double -p atVector |attrDest;
setAttr -type double3 |attrDest.atVector 0 0 0;
setAttr -e -keyable true |attrDest.atVector;
setAttr -e -keyable true |attrDest.atVectorX;
setAttr -e -keyable true |attrDest.atVectorY;
setAttr -e -keyable true |attrDest.atVectorZ; ... and, of course, I get the vector added no problem.
I have some lines in my script which attempt to do just this. The variables are $goodAttrName and $destObject. This just recreates the commands one by one into the string array $cmds[]. When all the commands are prepared, they are evaluated.
The commands are formed thus: (the very output from the 'print' command)
Which (unless I'm going COMPLETELY crazy) is exactly the same as the commands preformed by the UI addAttribute as shown above.
When these Commands are evaluated I get my vector added ok, but I also get three floating point values under them, named attrDest.atVectorX,Y & Z! Its like its ignoring the PARENT (-p) and just adding these as new attributes.
Please can anyone tell me how to add a (keyable) vector attribute in MEL sucessfully, given $goodAttrName (for the attribute name) and $destObject (for the object) ?
cheers -
Cybotic
//add attr
string $cmds[9];
int $c=0;
$cmds[$c]="addAttr -ln " + $goodAttrName + " -at double3 "+$destObject;
$c++;
string $dim;
string $dims[3]={"X","Y","Z"};
for ($dim in $dims)
$cmds[$c]="addAttr -ln "+$goodAttrName+$dim+" -at double -p " +$goodAttrName+ " " + $destObject;
$c++;
$cmds[$c]="setAttr -type double3 "+$destObject+"."+$goodAttrName+ " 0 0 0";
$c++;
$cmds[$c]="setAttr -e -keyable true "+$destObject+"."+$goodAttrName;
$c++;
for ($dim in $dims)
$cmds[$c]="setAttr -e -keyable true "+$destObject+"."+$goodAttrName+$dim;
$c++;
for ($c = 0; $c < 9; $c++)
print($cmds[$c]+"n");
eval($cmds[$c]);
