Aerender work even if a plugin isn't installed
Hello,
I use Backburner to render After Effect comp. on my renderfarm (with this script : Submit to Backburner).
Everything works well with backburner but here is the problem :
Previously, i used the standard network render engine of After Effect and when a plugin was missing on a station, the render stop.
But now, the render is made by the command line app aerender and he don't stop when a plugin is missing. So in my result (images sequence), some images are ok, some aren't.
Is there a way to set aerender to not render if a plugin is missing?
Thank you for your help.
Regards,
