I am so confuse with XSI's alpha channal. Is white meaning show? or black meaning show? Anyways, this is not my main problem. let's say, I am creating a dice. I have 2 pieces of texture. One is for the entire dice using white. Another texture is for the dots on the dice. I want to put 2 texture to it to make a blend. The dot texture, i put an alpha channel with it, all the dots are in white, and the miror area which i dont' want to show, i put it in black. 2 texture are set. And how do i put it in XSI so that the dot texture is sitting on top of the white texture and do a nice blend using my alpha channel.
ive seen a few tutorials around messing with this issue, but i cant remember the addresses, here is a good place to start:
http://www.edharriss.com/tutorials/tutorials\_comp\_xsi.html
I can't find anything simular.........
http://www.aldis.org.uk/Resources.htm
there you are...........
he has a ball with a few alpha alternatives.......
should calrify some things.
extra xsi specific web sites.
http://www.softimage.com/Community/XSI/Weblinks/
the internal softimage tuts:
http://www.softimage.com/Education/XSI/Sel...als/default.htm
etc, etc....
good luck
