Alpha channel enable?
I've a .pic file which has alpha channel. How do i apply to an object so that the object can show the white area(alpha channel white area), and the black area tobe transparent. I should put that in more detail. My .pic file is for hair texture. The RGB channels are the actual hair color. And i add an alpha channel to that so that it can look more like hair cutting edge insteal of a flat piece of picture. In SI3D, i will make the object metarial totally transparent, and when i add the .pic to that object, at the texture window, i switch it to "alpha channel" at map component, and i will adjust the transparency slider to -1. so that the white area on my alpha chanel will show, and the black area will not. That is how I do it in SI 3D. This is what i want to do the same in XSI, however, i 've try pretty much everything. Any idea?
There are a few tutorials on this page that will help you utilize the alpha channel. http://www.edharriss.com/tutorials/tutorials_materials_xsi.htmlhttp://www.edharriss.com/tutorials/tutoria...erials\_xsi.html
Especially these:
Layering textures and materials using the alpha channel in SOFTIMAGE|XSI
Using and image with an alpha channel
Transparency Mapping
Using the Rendertree to blend shaders
Render Tree nodes in XSI
Mix2colors : superposing 2 opaque images
Ed
XSI Videos, Classes, Tutorials, Tools, Shaders....
Available at:http://www.EdHarriss.comhttp://www.EdHarriss.com
Edharriss, thank you for your site. there has so many tutorials. However, I cannot find a tutorial that suits my case. please help.
Plug your image into the color2alpha node, then plug that node into your material type's transparency input.
Ed
It works now. However, i want to make it apply on both side. Now it only works on the side that the normal is facing, not the back. I understand it is becaue of the normals, but is there a way to make it apply on both sides?
You can either tell mental ray to render both sides (in the render options) or you can assign a "switch" node to your shader which will allow you to put a different texture (or 2 copies of the same texture) on either side of the polygon.
Ed
