hi,
i searching a macro, plug-in which can fill alphaholes. like the effect in ae called alpha cleaner. any suggestions where to finde. i looked here for it. but couldn
I personally dilate just enough so the holes are filled, then erode by one number higher, maybe two, depending on the alpha's feather. This leaves the holes filled, but the edges smaller than the original alpha. Then I'll take this filled, eroded alpha and either use either an 'add' or 'max' to combine the two.
so you build your holdout matte. ok, thats a way. but what i search is a simple macro that fill the hole
use groups... after all plugins arte just ammmut trees you dont se the interiors of!
sure i would use groups
so i guess there is no simple macro to fill holes.
thanks guys.
just do a hard matte and erode slightly and add some blur then use it as your holdout matte.
Easy one is for green screens is to max luminance red and blue, sub green, then use an expand to push the matte, then invert, viola instant hard matte.
